CobraGT40's avatar
CobraGT40
Trailer Wiring Conundrum...
Hi all
I'm not really sure where I should post this, but here goes.
I have a '98 Jayco Eagle 293-RKS that I tow with my 2000 Ford F-250. I had some right turn signal/right brake light issues when I hooked up to return from Wisconsin earlier this month. I figured it was an issue with the trailers themselves ( I tow a small 5x8 trailer behind my 5th wheel ).
Anyways, I decided to change out the lights on the small trailer with LEDs... same issue. Turns out that the issue is with the wiring harness on my TRUCK, not the trailers.
So, I picked up a Hopkins wiring kit (#40955), figured I'd just replace the one I have since the spring-loaded weather cover was broken. It says it's an "Exact OEM Fit". However, it does not work on my truck. After a bit of poking around online I found that Ford had 2 different factory wiring harnesses. One for 4 blade and a different one for 7 blade. My truck didn't come with a 7 blade (it was added by the guys that installed my 5th wheel hitch, brakes, etc.)
Anyways, I was hoping that there is an adapter so that I can use my new Hopkins kit (it has both 4 blade AND 7 blade...which I need since I pull a small trailer behind my 5th wheel as well)
Does anyone know if there is an adapter kit for this ...or another solution ? I truly loathe messing with any wiring... any ideas ?
Thanks !
Scott
