cummins2014
Nov 29, 2020Explorer
voodoo101 wrote:
I have a 2001 F-250 7.3 and I had to watch my tranny temps all of the time until I put the Ford V-10 tranny cooler on it. Now I never see 200 degrees. It is 40 percent bigger than the oem and comes standard with Ford tranny replacements. It should have been oem to start with since the 7.3 puts a bigger load on the tranny. Since it is an OEM for the V-10 it fits right on the bracket with no modifications.
Your Woods tranny may already have the larger cooler.
Good luck.
If you read his original post, you will see he has the 6.0 cooler, and would suspect its the same one the V-10 had, if not the 6.0 is probably the bigger cooler. 6.0 is 31 row.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
