a64armt wrote:
So the 2014 5th wheel we have agreed to purchase has Triangle TR656 14ply Load range G tires.
They were installed in Sept 2019 with little to no use since then (RV stored for winter).
Should I just commit to replacing these before a long distance road trip?
Thanks,
OJ
"They were
*installed* ...... etc.
Check the *DATE CODE* on the tires !!...:@
*If* it's reasonably close (within a few months) to/of Sept 2019 -
and you don't see any obvious sidewall cracking, etc. They're OK.
If you're still in doubt, take one wheel & tire to a tire shop you trust (or think you do) - have them dismount the tire. Examine the inside *yourself* along with the shop folks. (I would expect they will try to sell you 4 new ones).
If all looks good, then -
The answer is *NO* you don't need to replace them...:C
If the
*DATE CODE* is a "few" years older than 2019, I would be concerned (they may have sat on a tire shop shelf) before a buyer who didn't know enough to check - came along...:(
Yes.....that DOES happen - How do I know? They tried, I passed on the outdated tires the shop tried to sell me!
Buyer beware!
:W
