Mister-Mopar_5_'s avatar
Apr 29, 2014
Trimming some 5th wheel weight off
Howdy all I've had my Fifthwheel Camper now almost a year used it about 6 time's at the local lake's. I've been wanting to take it alittle farther then 40 mile's away to say Piegion Forge(250mile's). My family has always gone every year and stayed up in the mountain's in a cabin but, the price's are insane now a 3 bedroom 1 bath cabin 3 year's ago cost us about $300 for the week the same room today goes for well over $1000+ for a week and thats during the off season... So I belive it's time we started to spend that money on my 5er and just stay in it.
So what I'm wanting to do is to loose a few Pound's in the Camper.
Since it's probaly only gonna be me+/-2 more people I plan on removing the really heavy Fold out Couach/Bed and replace with a small Recliner,Remove The Table and 4 chair's, Remove The huge Recliner Replace with a Rocker with foot stool, The massive 32in TV for a 32in lightweight flat screen, the 27in massive Tv for a 19in lightweight Flat screen, Don't need the washer and dryer set(Alway's have one were we stay any way's. But that's kinda the way i'm going any other idea's or ways to cut weight?
It's not that I have any trouble towing it or stoping it at all just why carry more weight that i don't need. And i'm aware that i'm over my GCVW according to the number's when the camper is at GCWR. I made sure to check with my Friend who is a Kentucky DOT officer when i was choosing to buy it with all these number's and was givin the all clear and if i did have trouble he would fix it up no problem if it occured
Here's the Info on the Camper and Tow Rig.
Truck:
2001 Dodge 3500 DRW 4x4
24 valve HO Cummins 6 Spd
Upgrade List
BHAF(Aftermarket air filter)
CFM Oversized Intake manifold
Bank's Big head wastegate set at 40PSI
Boost, EGT, Fuel preesure, Volt Gauge's
Fass 150gph Fuel system with Big line kit
South bend Dual Disk Clutch #3250
Reese Fifth Wheel 26k Rail's
Reese 30k Gooseneck Adapter
Trailer:
1998 Newmar Mountain Aire 39BRSK
Bulldog 32k Fifhtwheel to Gooseneck adapter
Dual Tandem Axel's with dual brake's
Total length 39'11
UVW(Unloaded Vechile Weight) 14,140pd's
GVWR(Gross Vechile Weight Rating) 18,000pd's
Thank's for taking the time to read this and look forward to any help/advice y'all can throw my way :)
    Truck:
    Upgrade List
    Trailer:
    Total length 39'11
    Since you have the option of traveling with yourself +/- 2 people, I would choose the -2 people option which should reduce your payload by about 300-400 lbs, depending upon how robust the 2 people are.
  • My apoligie's I could have worded that better it's not that i want to lower the weight (which would be nice cause i won't BS you and say it pulls it no sweat because it is a heavy trailer). But i meant what way's can i upgrade the trailer to make it more to my likeing and also loose some uneeded stuff. Such as on our 33' Travel star camper we never used the bunk beds's so we removed them and made some really nice top and bottom storage place's along the back wall and opened up that whole section for other thing's. Or we removed one of the Kitchen bench's and table cause we eat outside or on the couach and just put a wall mounted "Pop up" mini table for the other bench. Stuff like that sorry about that.
  • Even loosing 300-400 lbs the truck won't tell any difference at the weight your pulling.
  • The truck info listed doesn't tell you anything about the truck capacity. Get the towing specs from the manufacturer and read them. Get the facts, forget personal opinions and speculation.
  • If you are OK...within your TV limits...just take what you have with you and be happy.
