parked on level ground with Hyper Lite trailer but rear gate has to much angle to load bike, no problem loading atv is there a solution or does anyone else have this problem
I'd block up the ramp a couple inches underneath the feet on the door (2x4, 2x6, whatever scrap you have laying around). My trailer has 3 feet on the ramp, I would just block underneath those to hold the ramp off the ground slightly.
You and the bike 'should' be able to climb the quick transition from ground to ramp; it will be just like going up a squared curb onto a sidewalk. The only issue you may have is your leg length if you are a shorter person.
