buxton132's avatar
buxton132
trouble loading Harley
parked on level ground with Hyper Lite trailer but rear gate has to much angle to load bike, no problem loading atv is there a solution or does anyone else have this problem
  • Raise the tongue as high as necessary to minimize transition between ramp and deck
    Run front stabilizers down to provide support..use blocks under if necessary so that stabilizers have wide stance.
  • Will raising the trailer tongue lessen the angle for you? Perhaps installing a winch system might help. Or how 'bout ditching the Harley and getting a smaller bike?
  • Too much angle to comfortably ride up, or too much angle at the transition from door to deck and the bike drags?
  • Where is the angle problem? transition from ramp to trailer? That is where my m-cycle did hit. I had to lift the ramp a bit to lessen the angle. My new trailer has a dove tail, so the ramp angle transition to the floor of the garage is not bad.
