Noles17
Apr 02, 2017Explorer
Truck Advice
Evening all, I am looking for a little truck advice. I currently have a travel trailer and am looking at upgrading to a 5th wheel by the end of the year. My current truck, Ram 2500 with 5.7, won't...
work2much wrote:Noles17 wrote:
Evening all,
I am looking for a little truck advice. I currently have a travel trailer and am looking at upgrading to a 5th wheel by the end of the year. My current truck, Ram 2500 with 5.7, won't pull the fiver so obviously I am going to upgrade there as well.
The 5th wheel we are looking at weighs around 15.5K lbs. I understand that I need a 1 ton, or its just the better option, but I do not want this size truck as my daily driver anymore. I am considering getting something to have as a utility truck and just to pull the 5th wheel. Any recommendations for under 20K? I am seeing a good bit of options in a F350, around 2004 or 2005 model years, with under 100K miles.
What are your thoughts?
It sounds like you will have 2 trucks then? Your current Ram and another truck just to pull the trailer? What about trading in the 5.7 for a 1 ton SRW that would be about the same size as your current truck? Many have payload capacities in the 4,000lb range which should handle a trailer that size.
