- reppoc12ExplorerYou may want to consider the size of the fuel tank. We added a 90 gallon vertical transfer tank with a gravity feed kit. It does not interfere with the toy hauler at all. We also keep a smaller removable box that sits below the rails in front of it.
RDS 90 Gallon tank - 1Adam12ExplorerDon't do what I did, which was purchasing a box that sits on the rails without testing to determine if you'll be able to see over the box while backing up to connect to 5er. My view was blocked and I had to make changes.
- Second_ChanceExplorer III installed one that doesn't come up above the bed rails so there's no chance of anything hitting. I know the "T" style boxes with wing doors are nice - and often sit above the bed so you can slide in a full sheet of plywood, but our truck only gets used for towing, so those were my priorities.
Rob
About Fifth Wheel Group
19,033 PostsLatest Activity: Mar 03, 2021
