Galena
Dec 18, 2014Explorer
Truck Dually Wheels
After looking at one ton trucks with dually wheels, I prefer the one ton trucks with single rear wheels. What would I be giving up not getting the dually wheels?
avvidclif1 wrote:wesdlewis wrote:
I have owned both, I have a 40 ft 5th wheel and a SWD (3500) now there are a few differences the stability is not as good and the brakes are smaller. I would never buy another SWD, stick with the DWD.
With a 40' 5th wheel you are probably over on all the ratings for a SRW 350/3500. And then wonder why it isn't stable and you need DRW. Duh
Cummins12V98 wrote:transamz9 wrote:Michelle.S wrote:
Granted you don't need an 8 Lb sledge hammer to drive nails, but at the same time you don't us a 16 Oz Claw Hammer to drive Rail Road Spikes.
You get what you need to do the job and forget about all the bandaids trying to make something do a job it's not up to.
So what you are say is that it don't matter if the OP buys a 2005 DRW or a 2014 DRW it will be better than a 2014 SRW?
I guess Ram is putting bandaids under their trucks now by putting air bags on them.
The bags are part of the suspension. There is only one spring now plus one bag on each side. So they have engineered the combo to do what they claim. It's not an add on/bandaid.
B.O. Plenty wrote:
So are you trying to say that dually pickups were developed for use only on the the oil fields?? I find that pretty hard to believe as there were duallies before there were oil field worrkers..
Allworth wrote:So are you trying to say that dually pickups were developed for use only on the the oil fields?? I find that pretty hard to believe as there were duallies before there were oil field worrkers..
How many people driving a dually realize that they were NOT developed to improve stability? The original purpose was to reduce ground pressure.
Oil field workers in West Texas and New Mexico found that the rear wheels of their pickups, when loaded with welding machines and other equipment, would break through the crust on the desert sand and bog down. Before cell phones and/or affordable two-way radio this sometimes brought about a long walk to get somebody to come pull them out.
Duals cut the rear ground pressure in half and reduced the break-through.
If you draw an overturning force triangle with the load apex at the trailer pin; the base right angle at the ground under the center of the rear axle; and the support apex at the center of the rear wheel(s) the difference in moment resistance between single and dual is almost negligible. If you look into the mind of the guy with the dually, the difference is enormous!
Half again as much rubber on the ground for braking is a different matter.
(Yes, I have used both to pull the same trailer and have gone back to SRW, but with a long bed. JMHO)
