MFL
Apr 03, 2022Nomad II
^^That is a fair size/wt FW, and hitch pin wt likely 3K+ maybe 3.5K, so may be more squat than you want. In any case, I'd hook it up, loaded to use, check for squat. A little squat is fine, and normal. If 4 or more inches lower than prehook up measurement, then suspension help may be best option. The DRW guys may have a better option for you. :)
Jerry
Jerry
About Fifth Wheel Group
19,042 PostsLatest Activity: Apr 15, 2026
