j09789
Dec 24, 2017Explorer
Truck tire pressure.
Recommended cold PSI is 60 front & 65 rear. They are Michelin 275/65/20 load range E on a 2017 F250 Power Stroke. Should I increase the pressure when towing my 39' toy hauler (Triton by Voltage)?
austinjenna wrote:If you are constantly towing something that is fine. But if you know what the max weight is of your heaviest trailer you may want to look up the proper inflation. 60k on s SRW truck with Michelins is NOT very good mileage. I would easily get 100-120k with Michelins on my 98 RAM 2500.
I think getting 100K on tires is pretty unusual but good for you. I cant remember every getting that type of mileage on anything I ever owned. I just fill mine to the max, same as the fiver tires and tow it. I dont want to make camping more complicated by filling up tires, releasing pressure, filling up again etc...
austinjenna wrote:WHY???
Because of this-> What Chuck said.... there is “no” reason to overthink this! Some folks would have you....dropping air pressure when you drop at a campground, and then re-air prior to departure. Properly inflate for the outing ( whether it’s a weekend or an across the country vacation), then take them back down after your outing. I leave mine at my desired pressure all the time. I tow several different trailers (of differing tongue/pin weights), and often not towing....I would forever be adjusting tire pressures. I can’t be completely incorrect...as I got just over 60K miles on my original set of Michelin’s.
WHY???
austinjenna wrote:
I also just run at max PSI all the time, towing or not.
ChuckSteed wrote:
I keep it simple.. When I know I am making a trip with the fifth wheel I inflate drive tires to maximum pressure stamped on side walls.. front tires I run at 65 psi...
I see no reason to run to weight scale all the time... been towing for over 40 years with many different rigs...
Weigh one time I suppose... I didn’t, don’t know and really don’t care... I know what the empty weight of the 5er is and I’ve got a few thousand pounds of gear in the fifth wheel..
My wife and I weigh about the same as always and have two 80 pound chows...
I run the fifth wheel tires at 110 psi... we tow at 62 and life is just fine
Cheers
