lee worsdell wrote:
here is what I weighted in at on my last trip. Some one please tell me where iam over iam pretty sure I am. driving a 2013 gmc 2500hd duramax,single axles slt model. front axel is 4806,rear axle was 6128 with trailer hooked up fifthwheel. The trailer came in at 9259 it says the trailer can weight 13300 loaded
As far as I know, all 250/2500 max out at 10k GVWR. So you're over that rating. The rear axle on most 250/2500 will max out at about 6k or 6,100, so you're over that too, but not by much. I would suggest you check your tire rating. Without getting into the whole spiel about the 2500 axle actually being the same as a 3500 axle, your tires should be your main worry. If you're okay on tires, I wouldn't sweat over it any more. Your truck will handle that fine IMHO.
