avgjoetx's avatar
avgjoetx
Truly lite toy hauler
I am hoping someone here has gone through this exercise and can help me out.
I have been searching for a toy hauler that I can pull with my Transit which has a 4500lb max loaded trailer weight. I want to Haul a 1100lb UTV. That leaves a max Dry trailer weight of 3400lbs.
Does anyone know of a <3400lb dry toy hauler? The only one I have found is the Livin Lite and it seems they have stopped production. Travel Lite has one that is close but the toy area is too small. Has anyone found other options?
Thanks!
  • I don't think you are going to find one. I have a 20' enclosed trailer and it is 2100 lbs empty, just my tools and gear probably added 500lbs, try adding beds, bathroom, fridge, tanks and all that and you are way over your limit.
  • rexlion wrote:
    KZ Sportsmen Classic 180th comes close, but only 9' long TH area.
    Wish they had a version w/o the bunks. That would allow plenty of room.
  • KZ Sportsmen Classic 180th comes close, but only 9' long TH area.
  • 1320Fastback wrote:
    Jayco makes the Octane which is pretty small.
    Years ago Weekend Warrior made the Supercross which was also very small.
    Both I fear may be a little above your dry weight.
    Looked at all current Jayco's. None worked. Don't really need small as much as lite.
    Thanks!
  • Jayco makes the Octane which is pretty small.
  • souraider wrote:
    Don't know the dimensions of your UTV, but that weight requirement is going to be a challenge.
    ***Link Removed***
    Thank You! I do need a 5x10 foot UTV area but might be able to get something custom.
