- IdaDExplorer
colliehauler wrote:
What sells the most TT or 5th wheel RV's?
Travel trailers by a wide margin. Not only are they cheaper, they can also be towed by a wider range of tow vehicles.
McDonald's also sells more burgers than In-N-Out. But give me a choice between the two and I'm not going with the golden arches... - colliehaulerExplorer IIIWhat sells the most TT or 5th wheel RV's?
- IdaDExplorer
rhagfo wrote:
Even at 30' to 33' a 5er is a big advantage, FAR more stable, inherently more stable!! With a TT even with a Hensley when the deification hits the rotary oscillator, the true pivot point is still 3' to 4' behind the rear axle! That will push the back one way and force the front the other way. I took too many engineering classes in school.
The step issue, I partly solved our issues by adding steps! Made each step smaller. added a step into the bedroom level and replace the three step entrance with a four step that all the risers are the same height.
Some of the TT guys swear up and down that the Hensley type hitches make their travel trailers tow the same as fifth wheels and those statements have never made sense to me. I guess I've never tried to understand the physics of it, but at the end of the day it seems to me that your physical attachment point is still 4' behind the rear axle and your travel trailer is still lighter on the tongue than a fifth wheel is on the pin. But I admit I've never used that kind of a hitch. - alexleblancExplorer
brirene wrote:
Absolutely. Better towing, much easier to hitch and unhitch, more storage, both inside and basement, higher ceilings.
everything I think - add to this shorter length while towing then same length TT so its easier to fit in parking lots and such. - rhagfoExplorer III
lawnspecialties wrote:
If I were looking for something around 30'-33', I'd probably prefer a TT. The bed of the truck stays empty and a properly set up WD hitch makes it just as stable and easy to pull as fifth wheel.
The only real reason I prefer a 5er is size. I can't imagine towing a 43' TT.
The step issue, I partly solved our issues by adding steps! Made each step smaller. added a step into the bedroom level and replace the three step entrance with a four step that all the risers are the same height. - PadlinExplorerSomething I missed.
We were looking for a small camper, in the roughly 20' range. Being 6'2" I required a real queen bed, everything I looked at except truck campers, had the short queens, till I found this one. - ol_Bombero-JCExplorerFirst TT in 1976
First (and only) 5th in 2006. Still have it.
Had all the "trick" add-ons for towing the TTs. Sway control, etc.
(Although never a Hensley).
Tow vehicles (for the TTs) over the years were two 3/4 ton vans, and a 1T diesel pickup.
Main advantage of the 5th - the difference in towing is night and day!
You can forget it's back there - no problems with wind, semis passing, etc.
Main DISadvantage of 5th: you lose the use of the bed of a pickup for "toys" (like MCs) that don't fit in storage compts.
If you have those - a 5th wheel toy hauler should be a strong contender!
Also - if you have bad knees, or? - the 5th usually has steps to the bathroom and bedroom. (TT is all one level). - lawnspecialtiesExplorerIf I were looking for something around 30'-33', I'd probably prefer a TT. The bed of the truck stays empty and a properly set up WD hitch makes it just as stable and easy to pull as fifth wheel.
The only real reason I prefer a 5er is size. I can't imagine towing a 43' TT. - dwayneb236ExplorerWouldn't go back. Love the room, the storage, easy to pull. All around better for us.
X2 !!!!!!! On every point . . . Will never go back to A TT . . ( IF I CAN HELP IT)
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
