- jffnkrnExploreri am at about four and a half years with my group 31 agm. They set me back about $250 each, twelve volt, and i haven't done anything with them since i installed them. They work great. as far as the sot comparison to regular $100 batteries, i am past the first whole year of breaking even. i will never not buy agm's again. maybe someday i can afford the lithium.
- Michelle_SExplorer IIIMy Magnum Inverter/Charger has settings for different AGMs, set mine according to manual chart.
- abc40kidsExplorerI just ordered an Odyssey Extreme PC-680 AGM battery.
- pianotunaNomad IIINice purchase Michelle. Do you have a way to monitor charging amperate, so you will know when the AGM's are full? How will you be charging them?
- Michelle_SExplorer IIIJust replaced my four 12V Flooded Batteries with four T105 6V AGMs. Now don't have to crawl into the front storage to check water levels.
- VeebyesExplorer IIAGM, especially the brands like Lifeline, are not cheap. The payoff is in the longevity & duty cycles of the AGM plus the no maintenance of it. It can go anywhere that you can find space to put it. No need to worry about venting.
- LwiddisNavigatorIt’s all about the numbers.
- pianotunaNomad IIICapacity on Optima is about 60% of a more traditional design. Cost is more per amp-hour of storage for them. If they were free--sure. But I want every amp-hour I can crowd into the available space without exceeding the carrying capacity of the batter compartment.
About Fifth Wheel Group
