salvador5266 wrote:
I know I've seen several topics on this but we are still confused:? We are just about to buy our first Fifth wheel but first we need to get a truck. We started out only looking for F350 because we thought that was what we needed but now we are seeing alot of newer F250 that show they have as high or higher Fifth wheel towing capacity. Did Ford revamp the newer truck models? Also is a vin search the best way to determine the towing capacity?
Any input would be great. Thanks everyone.
In 2005 the "tow wars" started and the numbers started to climb. With a 5er it's about carrying the pin weight. About 20% of the 5er's weight is carried on the pin/hitch in the bed of your truck. While a 2014 2500HD truck has a 4,000# cargo capacity most 3/4 ton pickups will not. Depending upon year and spec's it might only be 1,400#. The larger 5er's these days gross out around 16,000# (some hit 18,000#) or 3,200# pin weight or cargo capacity needed in addition to passengers, fuel and gear. If you are buying used, while the F250/2500 is popular the F350/3500 is the better choice. Example the 2014 2500HD has higher capacity than a 2004 F350 dually. All depends upon how new the truck is and how it's spec'd. A Diesel HD pickup 2500 or 3500 full of fuel and family is about 8,000# add 16,000# or so of trailer and you need a GVRW of 11,500# or better and a GCVWR of 24,000# or better. Majority of 2500's are 10,000# GVWR.
Honestly, many people have know idea what their actual weights are and over estimate what their trucks can do. The salesman says they can pull it and that's that. After all the Toyota Tundra pulled the space shuttle (tongue in cheek)
Do yourself a favor and either go big or buy the trailer and then the truck.
