John I Haggerty wrote:
I was just reading another post where the use of cinder blocks under the front legs is discouraged. My 5ths front legs are currently resting on 3/4" plywood over cinder blocks (one course high) resting on crushed stone.
What are folks thoughts on the use of cinder blocks in the front leg load train?
This weekend will be our second seasonal weekend where I usally re-adjust the front by adding two more sets of cinder blocks and a 4" x 4" spanning across the frame. I try to spread the front load across the 4 columns of block. This has always provided a very stable set-up.
Thanks!
I still can't figure out why people still block the front legs on their FW at all. Isn't that what the drop-extension is for? Personally, I use 1-2 "lego" blocks if I have any left over from leveling the axles and/or rear stabilizers, just to increase the footprint; a couple 2x4's side x side if necessary. Been wanting to screw a couple 12x12 1" pieces of plywood together to make feet, but have never got 'roundtuit.
Lyle
