Winged One wrote:
You really shouldn't be so unlevel your wheels are completely off the ground when level. Better to get it closer to level with blocks or repositioning first. It is safer that way.
We have the Lippert 6 point system. Lippert informed me that there is no problem if wheels on one side are off the ground. Here at home, the driver side wheels are a few inches off the ground. The system is designed for it. Lots of old wives tales out there about leveling systems. Our system will refuse to level if the 5er is more than 5 degrees off level.
Also we can use our system to "jack" the trailer for a tire change.
