BB_TX
May 09, 2013Nomad
Like others we always carry some water in the fresh water tank. When you run the pump it provides water just as if you were connected to a water supply.
Don't know about KZ, but some units have a "fresh water fill" switch near the fresh water hose connection. On mine I can rotate the switch while connected to the water supply and it will redirect water to the fresh water tank. Turn it back for normal use. I also have a fresh water fill cap, but rarely use it since I have the switch.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 25, 2026
