pennysmom09
May 11, 2013Explorer
ford truck guy wrote:
On my KZ I have 1 inlet for water with a throw valve below... With the valve facing 1 way he water is in the system... With the valve facing the other direction it will fill the water tank....Check to se if yo have an inlet for city water and an inlet for black water flush...THey should be the only 2 inlets you have... If you turn the valve the other way ,you should hear water running just a little bit ..that's good as it is filling up your tank...Joe
Thanks!! This is what we have....we will try the valve in our next trip.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
