pennysmom09
May 11, 2013Explorer
Camper Mama Bear wrote:
keep in mind that once you use the toilet on the road you now have what went into the toilet sitting in your black tank. if you are heading home you need a plan so it doesn't cause an odor problem sitting in the tank until you empty it out. some options...1 - can you dump at home? 2 - are you going out again in a few weeks or a month, if so consider putting a deodorizer in the tank (found in the RV section of walmart or any RV supply store). cooler weather you may not need to put the deodorizer in.
I personally am a strong believer in using my toilet whenever possible. so there are very few trips home when the toilet in the trailer is off limits. and for the next year or so with a little girl potty training those times will be even less because if I can avoid bringing her into a public restroom, I will.
That brought up another question.....if it is in storage....and right now it is and getting warm here....I noticed the small amount of water in the bowl has turned cloudy. I plan to go over today with some water, flush and also add a gallon and some chemicals. We will be going out again in a week. Is this the right thing to do?
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
