tourusa's avatar
tourusa
Vanleigh with nautilis p2.5 empty fresh water
Hi all is there any way to run this system with an empty fresh water tank, I know how to empty underneath the fifth wheel
1. does it refil automatically from the current setup on the panel
2. I’m in city water and want to keep the tank empty
  • Thanks all, I’ll try to drop the fresh water and if it fills check the seals
  • tourusa wrote:
    Thanks ken
    Looking at the setup I have with the nautilus picture does that look ok for just City water no tank fill
    Last year, I had to replace the valves on my 5er as one was leaking by and SLOWLY filled the freshwater tank. I am not sure of the piping behind the panel, but you need to check that you are not leaking by to the freshwater tank.
    Ken
  • Looking at the picture you posted you should be using city water only and no tank fill.
  • Thanks ken
  • You can have a leaky valve or a bad water pump check valve which can cause the freshwater tank to fill and overflow. I do not know of any that have an automatic tank fill system.
    Ken
  • Blue lever should allow operation from city water in horizontal,
