- 54sudsExplorerI had the tanks that were de-certified ? they were very lite and clear and fit the tank compartments fairly well . I now have two of these which are slightly larger and hard to see the liquid level with out shaking the tank.
I have been questioned about the recall tanks when refilling but never refused . If your worried about being refused you can print out a copy of the propane institute report to show these tanks are and store it in your propane compartment. - rider997Explorer
fj12ryder wrote:
Me Again wrote:
Do you know that for sure, or are you speaking of one local filler? And are they refusing because they think they are the ones that originally failed? IOW are they mistakenly refusing to fill them?
Right or wrong, more and more propane dealers are refusing to refill them. Chris
I don't have any, but I like the concept of being able to know how full the cylinders are.
The cylinders come with DOT certfication paperwork. I have not found any fillers who refused to fill the cylinders after being presented with the certification paperwork. Certainly there may be some who won't fill them, but it's likely to be out of ignorance or conflating the recall on old bonded cylinders (made by Lite Cylinders) with the safety of all composite cylinders. - rider997Explorer
ralphnjoann wrote:
Do the Vikings have to be recertified? If so, how do they stamp them?
The cylinders are stamped with a statement indicating they should be recertified every 5 years. In some jurisdictions they only need to be recertified decadally. - fj12ryderExplorer III
I don't have any, but I like the concept of being able to know how full the cylinders are. - Me_AgainExplorer IIIRight or wrong, more and more propane dealers are refusing to refill them. Chris
- avvidclif1ExplorerI was considering them but found out the height limited me to 22 lb cylinders and I didn't want to lose 16 lbs of capacity.
- ralphnjoannExplorerDo the Vikings have to be recertified? If so, how do they stamp them?
- rider997ExplorerHere's an older thread on Viking composite propane cylinders...
I own them and I love them. Very light and well made. Hexagon Ragasco (the Norway based parent company) products were never part of the DOT recall on composite cylinders. The cylinders weigh substantially less than even aluminum cylinders, and are about half the weight of a steel cylinder (a 17lb Viking cylinder weighs 10 lbs; a 20lb Manchester Tank aluminum cylinder weighs 17 lbs). I'd recommend them any day...
I converted from dual 30lb steel cylinders to dual 20lb composite cylinders and saved over 60lbs of weight from well behind the rear axle of my truck. It's one of the cheapest ways to drop that much weight that I can think of. - FlatBrokeExplorer II
crickeydog wrote:
fj12ryder wrote:
What? You expected only people who own the things to respond? Fat chance.
Yea I know. You'da thought by now after all these years I'da known better. But like anything else, ya kinda figure, "Ok, one last time I'll ask a question in hopes of a knowledgeable answer". Fifteen responses so far and not one legitimate answer. "DA" me. Lesson finally learned!!!:R No more questions!!!
Sorry, you asked if anyone purchased one. The answer mostly was no. Seems question was answered. - lylejiggsExplorerI have the 11# cylinder for my Weber grill. Expensive...yes, Doesn't rust...yes, safer than a steel cylinder...they don't explode they melt down. Lighter...yes noticeably lighter empty.
I tried to purchase the 31# cylinders this year and was told by Viking they don't make the 31# any longer due to low demand. They make the 22# for the front of travel trailers but I have 30# steel in my FW.
It was worth the price to me for the 2 year warranty, non-corrosive, lighter and safer. My Viking will likely outlast my two steel 30# tanks on the FW.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 10, 2026
