I am thinking of getting a VRV toyhauler. My total weight with gear,water,propane etc and weight of trailer should be about 6000lbs. I have heard that the tongue weight is about 10 to 15% of total w...
No, but you'd need to rhino line it to keep the water from getting in from outside or from leaking between the aluminum planks, walls, glues for the side wall composites, wiring, gas piping, etc. That stuff will still corrode. You'd also rather not have moisture between the planks left over from a clean out incompletely dry. A short trip later to the local mountains and you get freeze, thaw...in Geo we call it "frost wedging" :D it ain't good. Rhino lining would be warmer too.
