- austinjennaExplorer
I unroll it, spray it down, spray it with tiles
sorry I meant Tilex - Fisher_BillExplorerI think he meant TileX or some sort of brand name tile cleaner.
I unrolled mine 2' at a time and scrubbed top and bottom with Dawn soap and water, rinsed and rolled back when dry.
I think I'll try the simple green route next time to see if that helps with the stubborn stains - Duke-44Explorer
What are/is tiles? - KMLsquaredExplorerOne trick I just used was to detach the legs from the trailer and slide them under the trailer so the awning hung flat against the side of the trailer for easier scrubbing of the top side.
- austinjennaExplorerI unroll it, spray it down, spray it with tiles and roll it back up for about 30 minutes. I never needed to scrub it. If some spots are still there then repeat the process. Its the simplest way to do it I think
- ACZLExplorerWhen I do mine, I usually rinse it off 1st then use a dedicated brush on extendable pole, safety glasses and pour 2 qts of Tilex Mold & Mildew remover into a bucket and brush it onto both sides, underside 1st. Roll it up and let sit for about 30 minutes. Unroll and rinse off both sides and side of RV as well but the RV usually gets washed right after I do awning. Had old coach for 12 years and it's awning looked like brand new still, tho age was catching up to it and was due for replacement soon. Sold it before it got replaced.
In regards to using the Magic Erasers, I tried 1 once and thought it to be a PITA and when you have a long awning.........Plus how do you reach the top and middle portions of the awning(s)? - HammerboyExplorerGood tips on cleaning, I know this sounds obvious but never store your awning when it's wet. If you have to pack up wet, be sure to unroll and dry when you get home. That of course is only good if you store inside.
Dan - alexleblancExplorerTo my surprise I found that magic eraser works unreal to get rid of stains, Rinse well after use.
- BayouBoysExplorerSomeone is a local camping group recommended this product http://www.homearmor.com/product/e-z-wash-hose-end. I tried it this past week and worked great. Spray on and let sit for a few minutes. use a soft brush for the tuff spots and rinse throughly. This removed stains that have been there for years. It worked for me.
- stickdogExplorerBleach and dawn 1/4 cup of each ib 4gal warm water.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
