donewithtruckin's avatar
Mar 28, 2017
waste of money
Replaced all my suspension spring and rocker bushing in 2015. All were what they call" wet bolts" with plastic" so called" bushings. Great now I can grease them yearly and they will last a long time. The first year most greased very easy. This year unable to get any grease to go in. So I guess I should just let them ware out!
  • Wet bolts with plastic bushings? Where do you get that kit?
    I addition to 3/9 o'clock install I gave my grease openings a bit of a chamfer to help the initial grease flow.
  • rjxj wrote:
    Often times when wet bolts are used, bronze bushings are also used. You might try lifting the rig so that the axles drop and try greasing again with the pressure off everything.
    x2. That's a first step. Second step is to be sure that the bolts were put in so that the grease holes were horizontal. If they were put in vertically, then this is exactly what happens; the grease and dirt harden and plug up the grease holes. Also, I've =never= heard of a wet bolt kit that didn't have bronze bushings as part of the kit.
    Lyle
  • Often times when wet bolts are used, bronze bushings are also used. You might try lifting the rig so that the axles drop and try greasing again with the pressure off everything.
