Larryect's avatar
Larryect
Waste tank expansion (movement) on top side
Well, I had a real brain fart this past weekend.......
Was setting up and hooked up the water thinking I was hooking up to the city water inlet.
Instead, I had hooked up the water to the tank flush and turned it on.... Was sitting out side when we heard a "POP" and got splashed, then water started running of the roof.....
Well, shut off the water and started investigating. Figured out I hooked up to the flush and overfilled the black tank. Drained the tank and started looking for damage.
No sewage inside. But, the vent pipe and toilet moved upward with enough force to rip the toilet mounting screws out of the floor.
I decided to refill the tank from the toilet and check for leaks. Found no leaks. But as the tank got very close to full, somehow it flexes suddenly and lifts the toilet and vent pipe. The vent pipe moves upward about 3 inches..... Toilet not as much.
Would have been no damage except for the tank flexing. It seems really odd to me that the top of the tank would move that way and with so much force.
I am think of cutting the drain pipes apart inside the storage area and reassembling with flexible couplings to allow some movement so future potential flexing doesn't rip the toilet off the floor and ruin the vent pipe seal on the roof.
Have any of you ever heard of such a thing?
