MFL
Jun 30, 2022Nomad II
Seems obvious that the pump is not truly switched off. Unless the pump is running the water cannot continue to flow, other than a bit of residual pressure allowing slight water flow for a bit.
I suspect your on/off switch has failed. Most pumps make a little noise when operating. Some are fairly quiet, but you should hear it running.
Jerry
Jerry
About Fifth Wheel Group
