Cool_Canuck
Nov 16, 2014Explorer
fpresto wrote:Cool Canuck wrote:
It is normal for it to drip. Change it if you want, but I can assure you the new one will drip as well.
I don't know where you got this idea. Does your home water heater drip? It is exactly the same valve. A properly working valve can only leak if the pressure and/or temperature is too high. The OP's issue is either temperature or pressure or most likely deposits built up on the valve seat.
The first words in my post was to READ THE MANUAL. Every trailer came with one. That is where I got that idea.
I'll make it easy for you.
The Suburban Manual wrote:
Pressure Relief Valve
The temperature and pressure relief valve is designed to open if the temperature of the water within the heater reaches 210oF, or if the water pressure in the heater reaches 150 pounds. Recreational vehicle water systems are closed systems and during the water heating cycle the pressure build-up in the water system which will reach 150 pounds. When this pressure is reached, the pressure relief valve will open and water will drip from the valve. This dripping will continue until the pressure is reduced to below 150 pounds, and the valve closes. This condition is normal and does not indicate a defective relief valve.
Some may ask "what makes it closed?" There is a check valve in the water connection that prevents water from traveling back to the street. Rv's need this so you don't pump your fresh water overboard. Your house does not have such a check valve and the water pressure can back up into the mains.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
