bgiroux
Mar 20, 2022Explorer
Water will always migrate to the lowest point however the route it takes to get there is often unexpected. Remove the shower pan access panel and while someone is moving around in the shower with the water running, shine a light into the cavity or if you can reach the drain pipe with your hand, look for moisture. It’s an easy one to confirm or check off the list. Good luck. I know how frustrating looking for the source of a water leak is.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 10, 2026
