ssthrd
Mar 22, 2022Explorer
C Schomer wrote:
You could cap the pump inlet, close everything off and put a gauge and Schrader valve on somewhere and pressure test the water system with air pressure. That would tell if the leak is from the pressureized plumbing system without needing to see all Of it. Craig
Careful with air!
Unless you know what you are doing, testing with air is dangerous. Water does not compress under pressure where air does, so the more air pressure you use, the bigger the bomb you will build. Just 2 to 3 PSI is plenty.
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 10, 2026
