tchil's avatar
tchil
Water Meter
How many of you would like to have a water meter that told you how many gallons you had pumped out of your fresh water tank? Since the factory level gauges are so inaccurate I thought it would be a nice feature to have.
  • Please do not multiple post. She other thread running
    Admin
    RV. Net
  • Here is one you could install in pump discharge.....LINK
    Can't see our fresh water tank (enclosed underbelly etc).
    We know under normal circumstances we (2 adults 1 dog) can go at minimum 7 days on fresh water tank
    By then we are either moving or going to dump waste tanks so 'meter' is NOT a needed item for us.
  • I wouldn't want one. I really don't see the purpose. When the water in your tank gets low, you will refill it with your water jugs or take the RV to a water source.
    If you're at a full hook up CG, it won't matter.
    But, maybe it would make you more aware of your consumption while boondocking?
  • Most of us think the factory fresh water gauge is about the only one that IS accurate.
