MrRetired821
Mar 03, 2014Explorer
Water pump leaking
We had a night of freezing temperatures last night. While checking on my 2000 Excel 5th wheel, I found water under the trailer after I had run the water pump. Found when I run the pump water leaks out from the seam where the pump joins the vacuum and hose assembly. I am pretty much mechanically challenged. So my question is if I don't run the pump it seems I have no leak. However if I hook up to city water (which I always do) will there be any problem with leaks from the water pump. We have a trip scheduled in a week and no time to get it fixed. Thanks for any help.
