DutchmenSport
Sep 24, 2018Explorer
Had a similar problem a couple years ago, but the pulsating became more and more increased. Eventually, I decided to buy a new pump after LOTS and LOTS of exploring searching for leaks.
After I pulled the old pump, I found the problem. It had 3 screws completely missing that held the impeller assembly in place. I found 2 of the missing screws and figure the 3rd fell into the underbelly and I'd never find it. So I installed a new pump and never had the problem again.
Check the screws on the pump itself. Make sure they are all tight and not sucking or allowing the seal to be broken, causing the water to back feel into the tank.
And just an FYI, it only did the pulsating when the water heater was on. When the water heater was cold, the pump never did the pulsing.
About Fifth Wheel Group
