howardwheelerExplorerSep 23, 2018Water pump on fiver periodically pulsesMy water pump, which seems to work great as far as pressure and volume, every few seconds, maybe every five or so, slightly pulses. You hear a slight thump and the lights flicker just a slight bit. I’...Show More
partsman01ExplorerSep 26, 2018I also found on mine the drain tubes under for draining the plumbing were not tight enough
