agesilaus wrote:
The rated flow is 1.8 gpm vs the 3 gpm of the Sureflow pump that I have. So water flow will be low, you might have a problem with your shower flow. That sureflow is a diaphram pump too but it has a built in bypass. That pump you have seems to be designed as a sprayer pump, notice that it is not in the automotive area of amazon where the RV equipment is found.
It may work try piping it up outside the RV to the regulator and see if it works. If you are on city water do you even need a water pump?
My shower head is rated at 1.5gpm low flow if that helps.
No I have a rain/snow catchment system that runs to IBC water totes. I’m several hundred yards from my dads house I’ve got 12v solar that use for anything low power draw. And I have a 100A power pole that my dad had to run custom for me a while back.
Ok I’ll give that a try
