Colo_Native
Sep 15, 2015Explorer
Weber Q
I want to use the quick connect on the FW. I bought a hose but the fitting is for the regulator and I know you have to remove the regulator on the grill because it is already done for the 30# bottles,...
rwbradley wrote:
On the burner side it is 1/8" and most standard hose is 1/4" You probably are looking for a 1/8" to 1/4" if you are doing the same setup as me. You can get it at the gas fittings section of Lowes.
I did a detailed write up on this:
Link
