Colo_Native
Sep 15, 2015Explorer
Weber Q
I want to use the quick connect on the FW. I bought a hose but the fitting is for the regulator and I know you have to remove the regulator on the grill because it is already done for the 30# bottles,...
avvidclif1 wrote:rwbradley wrote:
On the burner side it is 1/8" and most standard hose is 1/4" You probably are looking for a 1/8" to 1/4" if you are doing the same setup as me. You can get it at the gas fittings section of Lowes.
I did a detailed write up on this:
Link
In your write-up all went well until the last paragraph.
"To create any other hoses for an external 20lb tank or for the throwaway tanks, all you need to do is get a hose of the correct length that has the right end for the type of tank you want to use, and a 1/4? threaded end on the other end. All you have to do is add a 1/4? female quick release and you can swap between RV, 20lb or Green throwaway."
Where is the regulator in this set-up?
