pohoda
Oct 08, 2018Explorer
lincster wrote:
I understand the difference in trailers.
I also understand you didn't go to 16".
I'm merely pointing out the fact that you need to check the inside surface also for rubbing.
Doesn't matter what size you go to, you need to check that and check it going over terrain as the suspension cycles.
Thanks lincster. Now that I checked I see what you mean. I think there is about 1" of clearance there. Definitely will check for signs of rubbing there. I am going to add a picture to the original post showing the gap and also mention that dimension.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
