Thank you for the reply and the link. I have mine sitting on jack stands right now. The tires are barely touching the ground, but I don't feel that theres any weight on the axles/suspension since we can spin a couple of the wheels. My stove cabinet is maybe 1/8 or less pulled away from the wall, and my wheel wells are up probably about 1/8" or less as well. I put a level where my door opening is, and it falls from the frame rails to the outriggers about 1/8". So maybe it's just not bad enough to where it can relax and fully go back? Any thoughts? I don't have a problem the way it is. Everything works, the doors open and close, the entry door doesn't have any issues nor the rear big door. Im just wondering if it's ok to just install more outriggers the way it is, or if it will/won't make a difference if I do.
