havasuduner wrote:
Well as a quick reply, I finished welding and put it back on the ground. Went inside to do the jump test, I can't see the walls going down at all when I jump, but instead I see them bowing OUT at the wheel wells. We looked outside where we braced the wheel wells and our braces aren't moving at ALL!! So I am unsure what is really going on now. I put about 10 new outriggers underneath and ran a new cross member at the front axle. Calling all people who have had Socal do your trailer, if you do the jump test, do your walls not bow out at all???
No, mine does not bow out or in at all,,, none. Rock solid. Couldn't believe the difference when they finished the frame/walls update. Feels like I've got a dozen stabilizer jacks all down hard its so solid. Walls are now like the rock of Gibraltar...
Like I told you earlier, iirr SCal RV DR added 6 crossmembers plus all the other frame upgrades and wall enhancements. And You added 1 crossmember...?
When they were doing mine, did get to see it at various stages of the frame/wall updates. They did say every unit is a little different in what it needs...
Good luck, keep adding metal and wood, you'll get it eventually.
jmo
