SMarquez's avatar
SMarquez
Weekend Warrior Lights
I am looking to replace a running light on my Superlight. It is a 3 diode light above the ramp door. Is this a WW specific light or is there another source for this light?
Thanks,
Steve
  • SMarquez wrote:
    eDUBz wrote:
    Im sure you can use any style trailer running light. I dont see why you wouldnt be able to use another brand.
    That would work if I were replacing all 3.
    You might try Benlo's in Baldwin Park. They stock a TON of LED's both inside and out, have a nice wall display. Talk to Tom the owner, very knowledgeable.
  • Google RV Tail lights then switch to Images and you'll probably see one that matches.
  • RoyB's avatar
    RoyB
    Explorer II
    I would look on the light lens and check for the word DOT stamped into the lens. This means the light is DOT approved... Some places may require your running lights to be DOT approved. I almost think here in VA they will require DOT approved types for all of the trailer SAFETY lights... Especially the ones visible from the rear of the trailer... DMV State Safety Inspection places around here really watch for those sort of things...
    I know I added some of those back-up lights from an ebay source below the rear square bumper on one of my trailers and had to physically remove them before the DMV would pass my State Inspection. They said if the unapproved back-up lights were mounted on the side of the trailer in the rear no problem haha...
    Roy Ken
  • Im sure you can use any style trailer running light. I dont see why you wouldnt be able to use another brand.
