Splashers3
Nov 04, 2019Explorer
I had my both the truck's and hitched trailer's tires individually weighed, which is even better than having the axles weighed (which I have also done).
I would recommend this if the situation ever presents itself. The guy then pulled out the tire manufacturer's weight vs tire pressure chart and told me what tire pressures I could safely run instead of the max tire pressure (in my case 110PSI) given the tire weights.
Safety should be a priority and Knowledge is always good.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
