howardwheeler's avatar
Jun 22, 2019
Weighing for side to side weights
If I weigh my truck and trailer (2017 F350 srw 6.7 and 2003 Alpenlite Portofino Villa) with one side of all axles on the scales and one side of all the axles off and then do the same with the other side, can I add the two together and get an accurate total weight? I did it to see if my drivers side, which has four large batteries and two slides on it plus the fridge, was significantly heavier than the passenger side. I know I can just go back and reweigh with all axles on scales but it’s an interesting question also that I’d like to know the answer to. My drivers side was indeed 1180lbs heavier than the passenger side. But is there going to be a difference between adding the two sides together versus weighing all at once because one side of the truck and trailer is always 90% on the scale and the tires on the other side are barely off the scale? I venture to say the two will be the same. What do you say?
