Y-Guy
Aug 14, 2021Moderator
HowlinDowlin - need a bit more info. I am not finding a Thor 38SG - can you share the model info? The weight ratings you need to consider are the garage rating as well as the overall capacity of the RV. Over by 30# in the garage probably isn't a deal breaker. But you will be over the suggested limit. Have you actually weighed your RZR or going by manufacture numbers? I ask since most RZRs get modified and may increase your weight. Final question, I am unsure what you are describing about the motorcycle ramp, are you meaning a motorcycle hitch carrier? The hitch rating and the garage ratings are two separate number, but without the specs to know the capacity of the RV it's hard to say if you're within the specs or not. While the Ford V-10 is very capable, just because you do it with the F350 doesn't necessarily mean you can do with with a Class A.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
