JUSTWORK's avatar
JUSTWORK
weight on slide out
I've got a 2015 Keystone Mountaineer 356TBF. This model has a sofa bed and dinette on the main living slide. What I would like to do is remove the sofa bed and dinette and replace with two double recliners. I called Keystone but they really had no information for me. Do you believe replacing dual recliner for dinette will cause slide issues?? Thanks....
  • Is your dinette sofa slide is hydraulic if so I wouldn't worry about it unless everyone sitting in the recliners are 300#ers.
  • Thanks for the information, the dinette just never gets used and during the day or evening it would be nice to have 4 recliners.
  • I'll go out on a limb having done something similar.
    The recliners are probably lighter than the sleeper sofa and the dinette and chairs. If I'm wrong, it's probably by less than 20lbs, so a non issue when you figure the weight of 2 people on the sleeper sofa and 4 people at the dinnete.
    Biggest thing to check is the depth of the slide. The base of the recliners has to be completely on the slide floor and there needs to be enough space that the back doesn't hit the wall.
    We did just the sofa and it was a great upgrade.
  • I see plenty folks do this. I think you could get a best guess estimate on weight after you remove them. Worst case, put in a pick up truck go get weighed, then swap for recliners and reweigh.
  • JUSTWORK wrote:
    Thanks and I will try Keystone again.... So right now I have on the main slide out one sleeper sofa and one dinette with 4 chairs. I want to get rid of the sleeper sofa and replace with a dual recliner and then get rid of the dinette and replace with another dual recliner so the difference in weight would be between the dinette and one dual recliner.
    SO 4 recliners vs sofa/bed & dinette
    Unless folks are in the 300# PLUS club I don't see an issue
    Weight of recliners not the issue.
    It's the added weight of 4 fat people (I use to be a club member at 385# but now 270# so I can call fat people fat)
  • I don't think anyone here can give an answer to the question. I/we don't know to what degree of overbuild, the slide mechanism of a given RV is? I have read, that you should not move slide in/out, if someone is sitting on couch/dinette.
    Most often, RV structure design is just adequate for intended purpose. So is an extra 50 lbs okay, a hundred lbs, maybe, but 200+, maybe not??
    Jerry
  • Thanks and I will try Keystone again.... So right now I have on the main slide out one sleeper sofa and one dinette with 4 chairs. I want to get rid of the sleeper sofa and replace with a dual recliner and then get rid of the dinette and replace with another dual recliner so the difference in weight would be between the dinette and one dual recliner.
  • You stated " What I would like to do is remove the sofa bed and dinette and replace with two double recliners."
    And then stated "Do you believe replacing dual recliner for dinette will cause slide issues??"
    Now which is it.........
    Remove sofa bed AND dinette
    OR remove dinette???
    Sofa bed & dinette.............2 recliners is NOT going to be an issue (weight wise)
    Just the dinette....table/chairs are not that heavy
    2 recliners could be much heavier then dinette set
    BUT slideouts are 'self supporting' when extended and the subfloor is pretty thick
    Not sure what yours is but the subfloor in my slideouts is 1" thick
    Call Keystone back........ask to speak with Factory Production Supervisor not some 'customer service' phone rep who probably is not even at the factory, never been to the factory and hasn't a clue about production
    I spoke directly with 'production rep' when I needed specific information
    **course now a days that maybe near impossible to contact one
    CUSTOMER SERVICE
    Goshen, IN
    (866) 425-4369 (toll free)
    ***ASK FOR TECH or Factory Rep
    Try calling CORPORATE
    Goshen, IN
    (574) 535-2100
