smurf wrote:
Well guys we have been full timing for 10 years / We have an 04 364 Everest 4 slides . I also have a 50 gal tanking my bed. OO I for got we pull it with an 04 GMC 2500 HD /Allison Tran. !!! I have 150,000 miles . I have weighted it full of fuel ( 80 gal )loaded 5th wheel and was a 150# over on front axle . We travel over west of the Mississippi River CO. WA. OR. Mont. ID. Ca. NM. Minn. And all points in
between .:)
Well, actions speak louder than words...it appears it works for you, and you're pushing the limits even more by adding an additional 365# of diesel fuel. You and the poster below you appear to make it work and both of you state, by mileage towing, it is quite safe...I still don't know if I would advocate towing, pushing the limit of trucks axle ratings, but I tend to err to the side of safety....BUT..... I guess the two posters who have been towing 14,000# 5er's, "noticed" that the OP's 5er has a GVW of 1500# MORE than their 14,000# 5ers at 15,500# GVW?? Significantly heavier, so if above poster is over an axle weight with a 14,000# GVW 5er, IF OP loads heavier than last two posters, would the two posters recommend for OP to "go ahead" and still do it:h..I can't advocate not being safe..
I towed just under 14,000# with an 03' Chevy D/A as I stated earlier with no extra fuel,and trucks configuration was ext cab/short bed....I did it, but on some mountainous secondary roads felt I needed a little more truck...I can't imagine on top of 14,000#, possibly adding ANOTHER 1/2 ton or more..I personally wouldn't recommend towing a 15,500# 5er with the 3/4 ton the OP has....
