Second_Chance
Jul 22, 2018Explorer II
GReeves wrote:
If you carry a pretty good load, I feel like your pin weight would be a fair comparison to what this campers pin weight would be, which would put me in the neighborhood of 6500-lbs on the rear axle. I know my dads truck does not have a GVWR of 10,000-lbs and his wheels/tires are rated for less weight than what I will be so if he tows it ok then I think I will be fine with swapping to the 285 tires. Thanks!
Did you come here for advice or to get someone to go along with what you've already decided? You will be too close to the limits with a 3/4-ton truck and that's a terrible tire/wheel setup for towing.
Rob
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
