eHoefler
Jul 22, 2018Explorer II
Just because the wheels and tires are good for the weight, does not mean the frame, springs, cooling, etc.. If your bigger than stock diameter on the tires, you whould be figuring you capacities with the next higher gear ratio, which will definitly put you over your capacities. Bigger tires and lifts, I know nothing was mentioned about a lift, will cause leveling problems, which affect load balance weights, etc.. Just a bad combonation from the get go.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
