Wiley123ExplorerFeb 18, 2020Welding outlet with 50 amp rv outletI am out of room for extra breakers in my breaker box. I have a 220 3 wire outlet for my welder in the garage. Can I branch off of that outlet and install a 4 wire rv outlet if I run a separate neutra...Show More
Chris_BryantExplorer IIFeb 18, 2020I think you could run a neutral and install a sub panel feeding the outlets.
Related ContentNo power on outside GFCI outletAdding power outlets in slide with no wiringElectrical outlet issuesOutlet problemElectric Outlets
